Full Version: kodi crashes while playing pictures by selecting a picture file and then playing
I have openelec with Kodi 17.3 installed and i have configured the pictures source to a NAS directory using NFS share
I have set to play next files automatically in settings
So whenever I open a pictures directory and select a random file and press "Play", Kodi displays 3 or 4 files next to the select files and after that it crashes
There is absolutely no issues with the pictures in the NAS.
Infact if i select the directory and press "Recursive slideshow" it works perfectly fine and shows all the files
I have attached log below which shows some read error. Can you please help
04:59:55.278 T:140401652579648  NOTICE: starting zeroconf publishing
04:59:55.279 T:140401652579648  NOTICE: CWebServer[8080]: Started
04:59:55.279 T:140401652579648  NOTICE: starting upnp client
04:59:55.319 T:140400618608384  NOTICE: ES: Starting UDP Event server on port 9777
04:59:55.336 T:140400618608384  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
04:59:55.744 T:140401633638144  NOTICE: VideoInfoScanner: Starting scan ..
04:59:55.974 T:140401633638144  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
04:59:56.307 T:140401035953920 WARNING: CSkinInfo: failed to load skin settings
05:00:01.499 T:140401633638144   ERROR: GetDirectory - Error getting
05:00:01.629 T:140401633638144   ERROR: Previous line repeats 3 times.
05:00:01.629 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:01.629 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:01.632 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/Folder/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:02.458 T:140401052739328   ERROR: Read - Error( -14, read call failed with " " )
05:00:02.458 T:140401052739328 WARNING: underflow: Error reading file - assuming eof
05:00:02.460 T:140401052739328   ERROR: Failed to close(nfs/Media/personal/Foldersdd/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:03.907 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:03.907 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:03.910 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:05.413 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:05.413 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:05.430 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2010 and before that/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:06.222 T:140401052739328   ERROR: Read - Error( -14, read call failed with " " )
05:00:06.222 T:140401052739328 WARNING: underflow: Error reading file - assuming eof
05:00:06.225 T:140401052739328   ERROR: Failed to close(nfs/Media/personal/memories/2014/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:06.960 T:140401044346624   ERROR: Read - Error( -14, read call failed with " " )
05:00:06.960 T:140401044346624 WARNING: underflow: Error reading file - assuming eof
05:00:06.962 T:140401044346624   ERROR: Failed to close(nfs/Media/personal/memories/2015/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:07.166 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:07.166 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:07.170 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2016_/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:07.406 T:140401044346624   ERROR: Read - Error( -14, read call failed with " " )
05:00:07.406 T:140401044346624 WARNING: underflow: Error reading file - assuming eof
05:00:07.410 T:140401044346624   ERROR: Failed to close(nfs/Media/personal/memories/2017/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:08.923 T:140401044346624   ERROR: Read - Error( -14, read call failed with " " )
05:00:08.923 T:140401044346624 WARNING: underflow: Error reading file - assuming eof
05:00:08.938 T:140401044346624   ERROR: Failed to close(nfs/Media/personal/memories/2017/01Jan/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:09.614 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:09.615 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:09.634 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2017/05may/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:09.782 T:140400300353280   ERROR: Read - Error( -14, read call failed with " " )
05:00:09.782 T:140400300353280 WARNING: underflow: Error reading file - assuming eof
05:00:09.798 T:140400300353280   ERROR: Failed to close(nfs/Media/personal/memories/2017/09Sep/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:10.686 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:10.686 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:10.689 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2017/10Oct/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:15.106 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:00:15.107 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:00:15.108 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2017/10Oct/Pictures/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:00:36.484 T:140401052739328   ERROR: Read - Error( -14, read call failed with " " )
05:00:36.484 T:140401052739328 WARNING: underflow: Error reading file - assuming eof
05:00:36.530 T:140401052739328   ERROR: Failed to close(nfs/Media/personal/memories/2017/10Oct/Pictures/Folder/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:01:28.563 T:140401633638144   ERROR: Read - Error( -14, read call failed with " " )
05:01:28.570 T:140401633638144 WARNING: underflow: Error reading file - assuming eof
05:01:28.571 T:140401633638144   ERROR: Failed to close(nfs/Media/personal/memories/2017/10Oct/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:01:33.456 T:140401044346624   ERROR: Read - Error( -14, read call failed with " " )
05:01:33.456 T:140401044346624 WARNING: underflow: Error reading file - assuming eof
05:01:33.475 T:140401044346624   ERROR: Failed to close(nfs/Media/personal/memories/) - close call failed with "NFS: Commit failed with NFS3ERR_ISDIR(-21)"
05:09:57.469 T:140401652579648  NOTICE: NFS is idle. Closing the remaining connections.
05:10:15.994 T:140400459245312   ERROR: GetDirectory - Error getting
05:10:20.420 T:140400459245312   ERROR: Previous line repeats 6 times.
05:10:20.420 T:140400459245312   ERROR: Unable to lookup host: ''
05:11:05.367 T:140401652579648  NOTICE: Storing total System Uptime
05:11:05.368 T:140401652579648  NOTICE: Saving settings
05:11:05.448 T:140401652579648  NOTICE: Saving skin settings
05:11:05.502 T:140401652579648  NOTICE: stop all
05:11:05.502 T:140401652579648  NOTICE: stop player
05:11:05.502 T:140401652579648  NOTICE: ES: Stopping event server
05:11:06.080 T:140400618608384  NOTICE: ES: UDP Event server stopped
05:11:06.430 T:140401652579648  NOTICE: stopping upnp
05:11:06.583 T:140401652579648  NOTICE: stopping zeroconf publishing
05:11:06.594 T:140401652579648  NOTICE: CWebServer[8080]: Stopped
05:11:06.594 T:140401652579648  NOTICE: stop dvd detect media
05:11:06.776 T:140401652579648  NOTICE: clean cached files!
05:11:07.131 T:140401652579648  NOTICE: closing down remote control service
05:11:07.131 T:140401652579648  NOTICE: stopped
05:11:07.341 T:140401652579648  NOTICE: destroy
05:11:07.341 T:140401652579648  NOTICE: unload skin
05:11:07.588 T:140401652579648  NOTICE: unload sections
05:11:07.600 T:140401652579648  NOTICE: special://profile/ is mapped to: special://masterprofile/
05:11:07.604 T:140401652579648  NOTICE: application stopped...
Sorry for this brutal warning at the beginning, but we prefer very much to have Kodi debug log (wiki) files NOT posted on our own forum, but pasted on sites like pastebin.com , paste.ubuntu.com and such alike. It's not fun having to look at code or logs files through a letterbox.
Also, always post FULL, unedited log files, and not just the parts that you think are interesting. Errors can originate from any moment on.
Thanks in advance.
Furthermore, OpenELEC 17.3 is an older Kodi product, and by now surpassed by LibreELEC, which has 17.4 onboard, and which will have the latest Kodi 17.5 in a week or so.
