(2018-01-19, 09:58)awesomeultimate Wrote: [ -> ] (2018-01-19, 04:36)Kyo* Wrote: [ -> ] (2018-01-19, 01:40)awesomeultimate Wrote: [ -> ]
Done + of this I can not
(2017-11-25, 21:01)vicius80 Wrote: [ -> ]Ok perfect....Can you insert this
is possible?
(2017-12-07, 00:09)vicius80 Wrote: [ -> ]the best thing is to put the info as well as the photo below:
-and finally you can put a nice player like the photo below?
and this player is fantastic. is possibile?
Someone knows if you can delete the items that are on the top left next to the word HOME: Favorites Search and Energy?
I do not want them there ... mainly Favorites because I added it to the main menu
link does not work, where can I download the skin?
Why did this skin die on us??
What happend??
Can anybody tell me what is the name of skin with this player ? I think it's something mod of Aeon Nox.
links are dead
(2018-09-17, 20:01)Nekromantik Wrote: [ -> ] links are dead
Bello 7 is coming...
Hi. Can you upload again?
I'm absolutely over the moon. So glad you are back
Thanks for updating this to Leia v4 beta but sadly this skin MOD doesn't work with Live Channels from within Android TV. If we change to Estuary it works.
What I mean is: You enable live channels on Android TV homescreen (Shield TV in my case) and you can customize it to show your library. Movies, TV Shows, etc. Once you click one item, it opens up KODI and shows that item's videoinfo. With this skin enabled, it opens KODI and then it does nothing, just sits there in the home menu.
Just writing this in case anyone was eager to test it out like I did. It just doesn't work.
Bello 7 is on the way.
For anyone interested:
Current RC5 nightlies is incompatible / doesn't work with the updated version of this skin. It auto-disables it as soon as you enter KODI.
It ran fine up until Leia RC3. RC5 onwards won't work.
(2019-01-03, 09:39)djhifi Wrote: [ -> ]For anyone interested:
Current RC4 is incompatible / doesn't work with the updated version of this skin. It auto-disables it as soon as you enter KODI.
It ran fine up until Leia RC3. RC4 onwards won't work.
Strange, I only just installed a fresh build of RC4 and this skin, working fine for me
