Full Version: Language Flags
Hi @marcelveldt
I've talked to Ronie and some other guys about language flags.
They are not set up properly and at the same time it's complicated to represent languages using flags (especially since some countries have multiple languages)
Could you please give users an option to choose if they want to use language flags or the default text way (ENG, FRA...)?
I have created resource.images.languageflags.completepack which actually uses the proper iso standards that will work properly with Kodi, so you should probably move to using that instead of current language flag resources.
Looking forward to your response!
