Does anyone know what the onclick command is to call the subtitles offset?
I'm trying to call it and can't figure it out.
Good question... On a keyboard it is:
CTRL+CursorUP or CTRL+CursorDown
but through API or JSON is apparently not documented (yet).
So no way to create a new menu/button to go directly to subtitles offset (yet)?
If I'm not mistaking I found it on the wiki how to do that.
If you didn't find it yet I will try to reply this evening if I get home from work.
Verstuurd vanaf mijn GT-I9505 met Tapatalk
(2017-10-30, 06:59)TRaSH Wrote: [ -> ]If I'm not mistaking I found it on the wiki how to do that.
That would be so awesome if you can help. I tried perusing the wiki and couldn't find it. Any help would be appreciated. My brain is fried. Maybe I'm staring right at it. lol.
Nice you found your solution your self I think I mapped that action to my remote.
Sorry for the late response but I think working 13 days in a row is acting up now
ZZzz..
Great idea! I'll try that next. Thanks again for the help... Get some sleep!
I can't still at work,
Need to wait till this evening when I get home for my 1 day weekend
In my userdate/keymaps folder i got the folowing
remote.xml with the following option added to my remote
<FullscreenVideo>
<remote>
<zero>Number0</zero>
<one>Number1</one>
<two>Number2</two>
<three>Number3</three>
<four>Number4</four>
<five>Number5</five>
<six>Number6</six>
<seven>Number7</seven>
<eight>Number8</eight>
<nine>Number9</nine>
<left>SubtitleDelayMinus</left>
<right>SubtitleDelayPlus</right>
<up>AudioDelayPlus</up>
<down>AudioDelayMinus</down>
<menu>OSD</menu>
<start>OSD</start>
<select>OSD</select>
<info>Info</info>
<!-- crash <teletext>XBMC.ActivateWindow(Teletext)</teletext> -->
<record>CodecInfo</record>
<green>NextSubtitle</green>
<yellow>AudioNextLanguage</yellow>
<blue>XBMC.ActivateWindow(SubtitleSearch)</blue>
</remote>
</FullscreenVideo>
This way i can change the subtitle offset by pressing the left right keys on my remote
(2017-11-04, 23:53)TRaSH Wrote: [ -> ]In my userdate/keymaps folder i got the folowing
remote.xml with the following option added to my remoteThis way i can change the subtitle offset by pressing the left right keys on my remote
Great idea! Thanks, that's so awesome and very helpful trick.
