2017-11-04, 15:00
Recently my HTPC stopped scraping new content. I was about to start the typical troubleshooting and make a log file, but then noticed that the HTPC in the living room also stopped.
If I navigate through the files, I can find and play the new content, so files are fine, and naming and folders are fine, been doing it the same way for years now.
I am using OpenElec, so hopped into their forums first, posted and response was that apparently OpenElec has issues with v2.0x of the scraper, suggestion was to downgrade.
So, I go into addons and the uninstall is greyed out, when I go to the repository, I don't see older versions, etc... I downgraded YouTube once a while back because of an issue that was soon fixed and so updated it again. Figured be as easy for the scrapers but no such luck.
Is there a way to downgrade the default TV scraper?
OpenElec suggested a downgrade but when asked how, that's kinda where the support died.
http://openelec.tv/forum/73-video-manage...ers#170977
