Full Version: Updated, now when adjusting the subtle offset it's not the mini sider at the top
So i'v done an update, and it seems now that when adjusting the subtitle offset, rather than closing the full OSD menu (not the pull up bottom bar one but the full audio menu) and having just the slider at the top of the screen, so you can adjust without the whole audio menu overlaid on the playing video.
Was the feature removed ? or do i need to default my skin and reload ?
Many thanks for an awesome skin. Subtitles seems to be an after thought in all over players, so my wife and I live in KODI.
Just tested with another skin Aeon Flux and it does what i expected.
i.e. closes the full audio menu and just give you the subtitle off set slide at the top of the video.
Is this just me or can someone else test for me ?
(2017-11-11, 17:29)cooljimy84 Wrote: [ -> ]Was the feature removed ?
not on purpose... but it seems it got lost somewhere along the way :-)
i'll fix that in the next release
That would be awesome !
(2017-11-12, 00:11)ronie Wrote: [ -> ]
Is there any i can do to get it back ?
edit a config or dev branch ?
add this line to DialogSettings.xml
xml:
<animation effect="fade" start="100" end="0" time="500" condition="Window.IsVisible(SliderDialog)">conditional</animation>
should be around line 13, below the other two animations.
(2017-11-13, 22:21)ronie Wrote: [ -> ]add this line to DialogSettings.xml
xml:
 PERFECT !
UR AMAZING
 Also my wife says thanks
