When I am on the home screen and have tv shows highlighted, it says "16 tv shows - 16 unwatched". This does not make sense because i only have 13 tv shows, in 13 different folders. When i open up tv shows, it even says "13 items". Why does the home screen say 16?? It should say 13.
In order to help you with your problem, please provide a
debug log (wiki).
Hmmm...
I wonder if this is because it's scanning:
'/var/media/Seagate Expansion Dr/TV Shows/Married... With Children/'
then later:
'/var/media/Seagate Expansion Dr/TV Shows/Married... With Children/Season 1/'
'/var/media/Seagate Expansion Dr/TV Shows/Married... With Children/Season 3/'
'/var/media/Seagate Expansion Dr/TV Shows/Married... With Children/Season 8/'
might be a coincidence but if you add the 3 season folders it adds up to 16?
Does "Married... With Children" appear correctly in your library?
Yeah it shows correctly. All 11 seasons, all 259 episodes, hmmm
Also, LibreELEC 8.2.0 is the latest stable build now. You are at version 8.0.4.
Quote:20:15:36.795 T:1947267088 NOTICE: Local hostname: OpenELEC
Apparently you switched over at some point?
No i never switched over, actually just started using kodi, i dont know much about kodi
Ok its fixed. I removed married with children from my library and rescanned it into the library and that seemed to fix it. Thabks for the help
No problem.
