How do i do this? I have hid the bg image on everything but when i go to info page for tv shows and movies it still shows the backdrop image. Im using the rapier skin
I will move your post to the Rapier sub-forum
Hi anderok.
Thanks for reporting the issue.
That's a lazy bug I haven't had the time to fix for a loooong time.
But I just changed the way fanart is handled in the libraries.
So now the fanart view option will affect the entire library (movies/sets, tv shows/seasons/episodes, pvr, albums/artists/songs etc etc) sections instead of only the selected view type.
This also means that from the next update, fanart will be enabled by default. So if you want it disabled, you have to change the setting again. But now it will also affect the information screens.
It will be available in the next development and official update.
Cheers
Gade
Thread marked as solved.
