is there a way to change the behavior of the way widgets move . I would like to make the widgets a fixed list, where the widgets would move around and into the focused position on both axis ..... this has stumped me for the last 8 months, any help and i would be eternally great full.
thanks in advanced
(2017-11-14, 04:33)Gtmnyc Wrote: [ -> ]is there a way to change the behavior of the way widgets move . I would like to make the widgets a fixed list, where the widgets would move around and into the focused position on both axis ..... this has stumped me for the last 8 months, any help and i would be eternally great full.
thanks in advanced
Yes this is an option in the skin settings of Titan BETA for Kodi 18. tick forced focus within the widgets settings. There is also a setting for enabling circular navigation or something similar
