2017-11-16, 01:51
2017-11-16, 15:20
A few questions (as obviously we can't ask for a log )
Which OS are you using, and which version of Kodi?
What exactly are the error(s) that you are seeing?
Are you meaning the log viewer add-on from the repo, or the log uploader?
Which version of the add-on are you using?
2017-11-16, 23:39
I,m using Android box with Jarvis 17 when I try to view my log it says error plead view log . The error message is on both log viewer and log uploaded this is a add-on from the repo log viewer 2.0.0 from kodi
2017-11-16, 23:45
The log file is just a text file, which you can access via an android file manager of you have one available. It can be found in one on the following locations:
Note: The first folder might be different on various devices:
If you can access it that way and then manually copy& paste it to PasteBin.com or somewhere similar we can have a look. Otherwise I think this one might be a bit tricky... 😉
- <data/sdcard/Android>/data/org.xbmc.kodi/cache/temp/kodi.log
- /sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
- /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
