2017-11-17, 06:21
Hi All,
Just looking for some quick assistance with the below, hoping you can help. Can you please advise which of these 2 boxes you would recommend
My other question is (and this is the important one), can I dual boot with both boxes? I'm thinking of purchasing a SD card to install LibreELEC Kodi and run it from there since I've heard it helps tremendously with performance but wanted to make sure it's possible on either box as I'm not sure what I need to be looking for in order for this to work.
Also, the Mecool doesn't have gigabyte ethernet whereas the H96 does, is there actually much or any difference with that? Like, would non gigabyte ethernet potentially cause buffering or slowness as opposed to the gigabyte one?
Any advice would be helpful, thanks in advance.
- Option 1: MECOOL M8S PRO Android 7.1 with 2GB DDR4 RAM - link to specs/more info is here
- Option 2: 4K H96 PRO+ plus TV Box Android 7.1 with 3GB DDR3 RAM - link to specs/more info here
