2017-11-21, 07:10
Hello everyone,
I'm having a problem with the "Clean Library" function and I hope you can help me saving some time.
This is the issue: doing a "Clean Library" takes really a lot of time, more than 30 minutes (and during the process Kodi in unresponsive).
I'm using Kodi 17.6 on an Android 6.0 Probox2 Air TV box, connected to a WD MyCloud EX2 Ultra NAS.
I've only two sources, Film and TV Series, that are two different folders on NAS.
The problem started when I changed my router, changed IP to the NAS and changed the communication protocol of my Kodi sources from NFS to SMB. To achieve that, I exported my library, searched and replaced in videodb.xml all occurences of old sources with new ones, than deleted old sources on Kodi (and so removing the whole old library, I suppose), imported the new modified library and manually re-added the sources using SMB.
I've already tried to rollback as much as I can but it has been useless: I exported the library, modified it back from SMB to NFS, re-imported the library, re-added the sources using NFS. Nothing changed.
My questions are:
01) Is there an easy way to fix this?
If there's too much work to do, I would prefer to re-create the library from scratch.
02) Is there an official procedure to follow for this kind of migrations?
I mean, if I have to change an USB drive source and so its name changes or if I change IP or protocol to my NAS.
03) How can I re-create my library from scratch without losing the status of my viewed items?
I've already read a lot of similar threads but most of them aren't solved:
Mac OS X - Kodi doesn't clean library anymore
https://forum.kodi.tv/showthread.php?tid=320419
Clarification of "Clean library..." & help to clean DB
https://forum.kodi.tv/showthread.php?tid=294011
Kodi 16 - Clean Library is taking too long
https://forum.kodi.tv/showthread.php?tid=277679
Kodi 17 - Why Does Clean Library NOT ACTUALLY DO THAT??
https://forum.kodi.tv/showthread.php?tid=312989
I would also like to try this plugin but there's a lot of work to do and I don't use any plugin or streaming service:
Beta - Database Pre-Wash Scrub - remove old junk links and privacy issues
https://forum.kodi.tv/showthread.php?tid=272112
I haven't read this yet:
[RELEASE] Texture Cache Maintenance utility
https://forum.kodi.tv/showthread.php?tid=158373
Thank you in advance!
My questions are:
