Appears to be a bug - tinyMediaManager ignores the aspect ratio flag in an MKV and calculates aspect ratio just via the video's dimensions (including if the crop flags are set, which I do like) - the NFO reflects the aspect ratio that tinyMediaManager calculates. The aspect ratio flag should take precedence, though.
could you send me a mediainfo-xml from such a mkv?
don't know how and if mediainfo reports the aspect ratio from an mkv..
just download mediainfo; open the mkv and export the results into an mkv (somewhere in the menus)
(2017-12-02, 11:32)mlaggner Wrote: [ -> ]could you send me a mediainfo-xml from such a mkv?
Sure - this is for the movie Morvern Callar. DVD is 16x9 enhanced I believe, and when I remove the black bars at top and bottom I get pixel dimensions of 704x464 (1.5:1), with a display aspect ratio of 1.85:1.
Quote:Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 6 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 6 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 2 641 kb/s
Width : 704 pixels
Height : 464 pixels
Display aspect ratio : 1.85:1
Original display aspect ratio : 1.85:1
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 148 r2708 86b7198
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
