Sorry, I tried doing a search on my issue and found nothing. I decided after months of using the stock skin on 17.x that I would go with another skin. I heard good things about Titan and heard it integrates well with Emby. After an initial basic setup I realized I was having issues navigating using my keyboard mainly.
When I use the 'Backspace' key to bring me to the side widgets(?) menu and then want to go to the power icon the arrows won't highlight up to those. So if I try to mouse over them it keeps closing the menu. It takes several frustrating tries to get to where I need to go.
Am I missing something.
Following I can't navigate to the power button as well.
(2017-11-24, 21:57)tjlmbklr Wrote: [ -> ]Sorry, I tried doing a search on my issue and found nothing. I decided after months of using the stock skin on 17.x that I would go with another skin. I heard good things about Titan and heard it integrates well with Emby. After an initial basic setup I realized I was having issues navigating using my keyboard mainly.
Does it happen in all layouts? If you press "s" to bring up the power menu does it happen? Are you using the beta from Marcel's repo or did you install from the get more button?
(2017-11-25, 16:12)disaacso Wrote: [ -> ] (2017-11-24, 21:57)tjlmbklr Wrote: [ -> ]Sorry, I tried doing a search on my issue and found nothing. I decided after months of using the stock skin on 17.x that I would go with another skin. I heard good things about Titan and heard it integrates well with Emby. After an initial basic setup I realized I was having issues navigating using my keyboard mainly.
No, hitting 's' brings up the settings menu and I can navigate with the arrows there just fine.
