2017-11-25, 19:42
Hey I am facing an issue with my intel nuc6cayh when playing back 4K HEVC videos, The issue is that following artifacts are appearing https://i.imgur.com/qevgQII.jpg (picture is not mine, on my unit there are actually 3-4 different areas that are blinking with this effect).
this does not affect all HEVC 4k content... only some. Here are the examples that are affected:
https://i.imgur.com/vq8vll8.png
https://i.imgur.com/yEurYsa.png
here is one that is not affected but still 4K HEVC:
https://i.imgur.com/XJInrkj.png
all 3 movies are playing back with vaapi-bob.
The only difference I can find is the mkvmerge version used to create these files but I cant find anything in the changelog of the program that would help narrow down this problem.
I have seen suggested in other posts that this is caused by having enabled enhancement under Video Settings in Intel HD Graphic Control Panel but this seems to be only the issue on windows.
Running libre elec 8.2.0 with kodi 1.7.5
Here are some logs I dont know if they will help anything.
https://paste.ubuntu.com/25878486/
The unit have this under the hood:
CPU: Intel Celeron J3455 CPU, quad-core, 1.5 GHz (2.3 GHz burst), 10W TDP
GPU: Intel HD Graphics 500, 12 EUs, 250 MHz base frequency, up to 750 MHz
Thanks for the help
Thanks for the help
