Full Version: Slideshow - picture zoom
Hello,
I noticed that when I watch pictures in slideshow mode, they are expanded so they fill completely the screen.
My photos being with a 3:2 ratio, and viewing them on a 16:9 screen, the top and bottom areas are cropped.
Is there a way to disable this zoom during slideshow ?
Thank you,
mat
Yes , this can be done in the settings in the pictures section. (If I am not mistaken) It definitely can be done
That's my settings for the picture section. The zoom effect is disabled, but the pictures are still expanded...
I got this issue only in slideshow mode, not when double clicking a specific picture.
Could someone help me find the right option ?
Thanks,
Ah ok. That's way I meant. Should be good like this. And if it's not thenb I don't know what the issue is. Sorry.
Was looking for the same thing, found the solution here:
https://trac.kodi.tv/ticket/12565#comment:11
I also have the same status as you also on many forums find out but still no answer satisfied, Does anyone know please guide, thanks
There is a quite simple solution.
Add the following in your advancedsettings.xml:
xml:
<advancedsettings>
    <slideshow>
        <blackbarcompensation>0</blackbarcompensation>
    </slideshow>
</advancedsettings>
That's all - works fine Smile
