Full Version: Black screen before screensaver initialize
I am try to write a simple screensaver for RaspberryPi,
it ower PWM pin slowly disable backlight of lcd display.
It works, great. But after screensaver is started
the screen is filled with black color. As i discovered
it happens immediately before screensaver starts.
Is there a possibility to disable this behavior?
(2017-11-28, 14:56)jirit Wrote: [ -> ]Hi,
 It happens with me also. please let me know if you found any solution.Regards.
What happens if you disable the screensaver? And test the behaviour via ssh?
