2021-05-15, 20:42
(2021-05-01, 02:01)Droidly Wrote: [ -> ](2021-04-29, 07:21)vtwin0001 Wrote: [ -> ]I'm having that same error...Thanks VTwin0001, I will give it a try but I haven't worked in the sqlite database before so I will try to proceed with caution. Maybe you can give me some detailed advice? If not now worries and thanks again for the info.
Are there any solutions?
Has anyone found out what is going on?
@Droidly I had the same problem as you did, it was scanning the whole thing. I opened the sqlite database file and made the changes, now it's working as it should. It only scans some folders I appontt he addon to.
I am a windows 10 user but I have added an sqlite editor.
Droidly
I use SQLiteStudio... First I had the normal .sql file, then when I moved all my files to another drive, someone told me to delete my old file and rescan the whole thing (this is a huge mistake, to me)
Then, I moved my sql file and also someone here at the forum told me to export the whole thing and reimport it to make a MySQL file. This was to me a mistake as well, since there are scripts that can convert the sqlite file to MySQL back and forth with just a little tweaks here and there.
Finally I changed back to a .sql file. This is to me the fastest way to manage a huge library
I use sqlitestudio, however I not an expert.. just a user that likes to poke @ things XD
I no longer use windows, but you might be able (I guess) to find the addon_data folder and inside you'll find this plugins folder (plugin.googledrive). Inside you'll find the exports.db file.
Open this file with your sqlite editor and there you'll find a table called 'store' (remember to use a copy of the file and not the original, just in case), edit the table
Inside youll find 2 columns: key and value.
I go to value and check what it says, and change from 1 to 0 if I dont want it to do whatever its doing wrongly and viceversa
{'schedule': 0, 'run_immediately': False, 'watch': 0, 'driveid': '123456789123456789', 'update_library': 0, 'content_type': 'video', 'schedules': [], 'item_driveid': '123456789123456789', 'download_artwork': 0, 'name': 'New', 'destination_folder': '/home/aaa/Desktop/DB/STRMS/', 'id': '123456789123456789', 'exporting': False}
I have no idea LOL if I made it right (I guess I did), but I believe 0 means NO and 1 means YES
(2021-05-01, 04:00)WarPirobo Wrote: [ -> ]i've used this addon for years and im thankfull for but now i had moved on with another addon that is providing me things i wished forCode:
https://github.com/fandangos/rclone-addon
i was able to to use a different cloud storage provider and even use crypted data directly to Kodi using my TV BOX with this new addon, it is very easy to set up.
Aw.... just when I finally was able to make my whole KODI setup easy to manage I have to change to this one, since this Google Drive for Kodi addon seems to be abandoned. I have to re-edit my DB and change everything for rclone.. :/
