(2021-10-27, 19:27)raghnarock Wrote: [ -> ]hi anyone know how to workaround this problem since a few days i wasnt able to access google drive with the add on in kodi
anyone can help please?
WHat is the error you are recieving?
(2021-10-29, 19:44)Zarquon Wrote: [ -> ] (2021-10-27, 19:27)raghnarock Wrote: [ -> ]hi anyone know how to workaround this problem since a few days i wasnt able to access google drive with the add on in kodi
when i need to authenticate with the URL, it nevers appears, before i have it configure it but i wasnt able to explore my drive folders so i reinstall it but now im not able to even connect can anyone help me?
Does anyone share this experience about google drive?
There are some files with 10 GB or more that open within 5 seconds, but there are files with only 2 GB open in 45 seconds.
The same 2 GB file, sometimes opens very quickly. Is this the default of Google Drive. Is it possible that a service running in the background is in contention with Google Drive for resources? Is there any way to improve this?
I don't believe the hypothesis that my network is unstable. Because only Google drive I have this problem. Files uploaded to other hosts like PCloud, OneDrive... never have this situation.
My system is CoreElec 19.3 on amlogic s905X3
Goggle drive version 1.4.10+matrix.0
the incident solve itself, i dont know if there was an update in chromecast with googletv or kodi
EDIT:
doesn't works on 19.3
same issue
Hi there,
I am trying to use this add-on in Kodi, but I can't seem to log on. Whenever I try to authenticate (by entering the code on drive-login.herokuapp.com) it says 'Your code is invalid'.
I don't think I'm doing anything wrong tbh.
Could someone please assist?
Thanks in advance!
Nick
I just installed the addon and managed to add an account. The website accepted the code without issue. Maybe try another device.
Since a few days ago, something is deleting my exports folders completely (Movies and TVshows), so that no item in my collection is playable because the .strm file is no longer found, and I have to re-export everything. This is happening randomly across various devices on Android TV and Windows, with Kodi Matrix, each with its own different settings.
Is Google Drive sending a false positive that the source folders has been deleted? Or is the addon misinterpreting some signal? I haven't altered my Google Drive folders in any way in years, except to add new content.
Kodi Google Drive Addon Freezes on Android
I'm on Android 11 and running the most recent version of Matrix 19.3
The Google Drive addon is lagging so bad that Kodi all but freezes.
It got so bad that I tried a fresh install and was able to get it mostly working for a while.
Late last year & early this year, I could play films, but now they are freezing after a few seconds and kodi completely shuts down.
I've checked out Reddit, github and now here.
It seems that a few people have posted these issues on guzzman's github:
https://github.com/cguZZman/plugin.googledrive/issues
Freezes, restarts, not working, crashes etc in the issues.
I just wanted to reach out to this community and see if anyone has any suggestions or ideas.
Any info would be greatly appreciated.
I solved the problem adding these lines on advancedsettings.xml
<network>
<disablehttp2>true</disablehttp2>
</network>
(2022-01-18, 23:22)WarPirobo Wrote: [ -> ]Move to RCLONE, i did a long time ago i use it with TIVO STREAM 4K and AMAZON FIRE STICK 4K using this addon.
https://github.com/fandangos/rclone-addon
Does this require another machine to be running?
If yes, I don't have that option...
If no, please elaborate because I'm missing something.
(2022-01-19, 18:19)Carvajal Wrote: [ -> ]I solved the problem adding these lines on advancedsettings.xml
<network>
</network>
Thank you for the suggestion, I added this line, but still not working.
If I start a video (movie / tv) the whole thing freezes within a few seconds and the kodi either stays like that or eventually crashes.
From what I've read this solution worked on older versions of Android (10,9,8 etc..)
Are you using the same setup as I am?
Are you on Android 11?
Are you on 19.3?
I'm still on Android 9, but I have Matrix 19.3. With these lines I solved the problem with the freezes...
I will not upgrade to Android 11 until Nvidia solve a lot of bugs.
