(2022-02-11, 03:23)Mathalete Wrote: [ -> ] (2022-01-31, 19:11)kim1406 Wrote: [ -> ] (2022-01-19, 18:19)Carvajal Wrote: [ -> ]I solved the problem adding these lines on advancedsettings.xml
<network>
<disablehttp2>true</disablehttp2>
</network>
Thanks, I can confirm that after adding those lines in the advancedsettings.xml file, now Kodi is working great, no issue with Google Drive. Great post.
How do you add the file to the nVidia Shield? No matter what I do, I cannot navigate to the appropriate user settings folder mentioned elsewhere
Sorry for late reply, I added it via my pc through Local Network.
I have noticed that when using Kodi 19 on Nvidia Shield (Android), downloaded subtitles of exported files by google drive addon, will be saved in very odd naming format, something like : 191sUgI7-suBgm0UUwTVnH2OWrYh-aueK.srt. Is there any solution to this? Thanks.
Hi. It turns out I'm not as technologically advanced as I thought I was. I'm having trouble creating the required advancedsettings.xml file to stop the buffering issues I'm encountering with v19.4. Could someone perhaps send me step by step instructions as to creating the file with the proper line breaks, etc. using ES File Explorer? I am using a firestick but have access to whatever other technologies that may be easier to work with.
Or, another thought, if anyone has an idea as how to downgrade back to Leia with a functional Google Drive addon that would be great too. I have multiple TB of movies on a Google Drive account that have become unwatchable and I'm desperate for a solution.
