Is there an ETA for the fix? Really looking forward to using this ASAP
(2018-05-29, 16:52)cguZZMan Wrote: [ -> ]@woomg sure you can.
You just need to clone the login server from GitHub, compile it and run it. It runs with java and can be build with maven.
You need to pass your clientid and secret as environment variables when you run the server.
Also you would need to modify the value of __api_url from the file plugin.googledrive/resources/lib/provider/googledrive.py to point to your server.
I will try to put some documentation in github to easy the process for those who want to implement their own login server.
I haven't tested it with a headless kodi but, yes, coping the addon_data for the addon (which includes your configuration) should be enough.
Thanks a lot. I will try that.
I wanted to use this app and have ran into a problem. when attempting to play some of my videos, i get the error "cannot concatenate str and nontype objects", what does this mean and does anyone know how to fix this? Also reading around, i noticed some were having problems using the url to add an account, I too was having the same issue where google had yet to "trust" the app but I was able to log in by opening the url on my android phone using firefox, chrome did not work.
EDIT: here is my log file
http://paste.osmc.tv/anenucidux
I got the authentication to work. I was wondering if its possible to add Team Drive support? All of my files are on that (unlimited storage)
thepagal it's in the list of enhancements. Will be added in the future. No ETA.
I've started getting this error message after selecting my Google account after entering the code via
https://kodi-login.herokuapp.com/auth-success - is this a known issue? I looked through the latest posts but couldn't associate them to this:
Sign in with Google temporarily disabled for this app
This app has not been verified yet by Google in order to use Google Sign In.
Hi i"m new here
there is option to add the same account to 2 computers?
This app has not yet been verified by Google for use with Google Account sign-in.
may you help?
daherlihy @
shaharLe88 the verification is in process and is known issue.
Yes you can add the same account in as many devices as you want.
so how can i fix the massage i get when i try to add another device?
shaharLe88 you don't need to do anything. Just wait until the verification is completed. I'll post a message when this is done.
Really waiting to get it working again ... got a new device ... this plugin is a must have
For people trying to do the verification step: Use Firefox on your phone for this step. For some reason it works
in the computer the firefox will work too?
