Full Version: Google Drive for KODI
I just installed it how do I update it
download the zip and go to kodi> addon> install zip file. It will be updated.
​​​​​​​https://github.com/cguZZman/plugin.googledrive
The version that is in the official repo is not updated.
(2018-06-23, 00:34)KingKaka Wrote: [ -> ]
(2018-06-22, 17:36)FevLoad Wrote: [ -> ]Couldn’t get this plugin to work for me
getting when try to put the code i get from kodi.
Quote:Your code is invalid. Make sure you entered the code displayed in Kodi and you're in the same network as your kodi device.
Browsers used:
Firefox ( didn’t work)
Chrome ( didn’t work)
I had the same problem before. Make sure you follow the URL from kodi. I noticed that the URL change kodi-login.herokuapp.com or drive-login.herokuapp.com
Update (1): still the same, and I don't know why.
Update (2): Worked.
Question: is it possible to add the files to my library and get info for each folder?
Create .strm file is the fastest way. Add the folder to kodi where you set it to create the files.
Is there a limit to how many files this can handle? My main movie folder of 3100 movies is failing (something  went wrong with this operation. please try again later) when using the "export to library (strm)"  Ive updated to the latest 1.0.3 and it solved the issue with smaller folders but the main one keeps erroring out.
(2018-06-26, 19:57)famulor Wrote: [ -> ]Is there a limit to how many files this can handle? My main movie folder of 3100 movies is failing (something  went wrong with this operation. please try again later) when using the "export to library (strm)"  Ive updated to the latest 1.0.3 and it solved the issue with smaller folders but the main one keeps erroring out.
Folder is Max at 100. He's looking into it. Can you please provide a log so he can compare it.
Is there a way to use google drive to backup and RESTORE my kodi configuration?  I was hoping to use one of the backup/restore add-ons, but when I try to point to the google drive for restore, it is not allowed.
@Bilbo310 you can also update it by installing my repository: https://github.com/cguZZman/repository.plugins
@Joe1RI it's not possible. The addon right now is intended to read your files only. No write or modifications to your drive.
@cguZZMan
   Any news ?
 - update on automatic strm?
 - information about the movie during playback, of movies that are already in the kodi library in strm format.
No news. I've been busy these days
I Love this Addon, but have a bug is list movies cannot sort by alphabet
@tremocoivo  do you have the latest addon version? If not, please install my repository https://github.com/cguZZman/repository.plugins and try again.
Let me know
@cguZZMan yes, it's working, thank you. And I have an problem that is when I config account gg drive successful and I share my account (file setting.xml) to my friends (about 100 users) and have many users cannot be play movie and show error like this
Always post an issue with your kodi log: https://kodi.wiki/view/Log_file/Easy
(2018-06-23, 00:28)KingKaka Wrote: [ -> ]
(2018-06-22, 16:16)cguZZMan Wrote: [ -> ]@iorifly I'll check if that's something about the addon.
@KingKaka Is the normal listing displaying all the files? I'll check the exporting issue you reported.
Yes. I have 100+ folders within 1 main folder. I will send my log when I get home tonight. If I add localhost:port#/source, I have access to all folders. Just the .srtm file creation. Log: https://paste.kodi.tv/eniricavev
Thank you so much. One of the best kodi add-on.
Any time frame on the automatic .strm file update?
Hey @cguZZMan how are you doing. The folder limit 100+1 is only accessible through the app. Creating .strm file gives an error or browse the folder through localhost:8585/source only shows max of 100 folders.
Take a look please thank you.
https://paste.kodi.tv/eziduyuqug
