Full Version: Google Drive for KODI
Post your debug log file.
Hello cguZZMan, I do not know if it was said, but at least today, I noticed a problem or something changed in the googledrive. My movies are in a folder on goodrive, and I share with 5 friends, Those who have only View Privileges movies, they do not run. Well below two logs, I do not know what you need. These logs are from CoreElec running on a Mecool Pro L. If you need the same error on a Raspberry Pi2, Raspberry 3 and Odroid C2, I can, but I did a quick test, I added an account on Odroid C2, and the same error continues , LibreElec-Kodi, in the case, access the page, I can save the stream, however .. via library, neither via direct addon is running, nor using path localhost-8587.
https://paste.kodi.tv/everinalik.kodi
https://paste.kodi.tv/uteqaxomuk.kodi
(2018-12-04, 17:19)cguZZMan Wrote: [ -> ]Post your debug log file.
 here my log http://paste.kodi.tv/ahavavekec
Updating I think I figured out the problem. The account with the movies is centralized, ie an array. several accounts share to the parent account, in the "daughters" accounts it is enabled, that you receive the share from the parent account and have only the can view, can not edit and download. So that's it, if the movies are being shared, with the blocking of download and editing, for those people who can only view, so the movies do not run.
(2018-12-04, 03:46)cguZZMan Wrote: [ -> ]@extremeaudio Yes it would. Kodi does scan strm files. No need of nfos. You just need to name your folders or files correctly and Kodi will do the rest. Take a look on https://kodi.wiki/view/Naming_video_files/Movies
@efegue You can download a file. Take a look here: https://github.com/cguZZman/plugin.googl.../issues/27
@keithcq71 the invalid code must be for a reason but I always need more information that just reporting it. I need debug log files or something useful. Not really sure about the team drive question. Can you explain what a unlimited device is?
@navysandsquid the separation of files is totally up to you. You can organize your movies in your drive as you want/need. The addon will help you exporting them so you can add them to your library and also it will help you playing them.
@alexprimaid I need more information than that. Please always post your debug log file if you want to report an issue. You should be able to export, but take in count that Kodi is not scanning music from strm for now. It's a kodi issue (it's stated in the first post of this thread).
@melmanc Please always post your debug log file if you want to report an issue.
 They are trying to enroll from the website https://drive-login.herokuapp.com/
@niltoncrf glad you figured it out.
@alexprimaid your log doesn't contains any debug message. Follow the instructions from here: https://kodi.wiki/view/Log_file/Easy
@keithcq71 that is not useful. Please post your debug log file: https://kodi.wiki/view/Log_file/Easy
(2018-12-04, 03:46)cguZZMan Wrote: [ -> ]@melmanc Please always post your debug log file if you want to report an issue.
sorry.. here you go: https://paste.kodi.tv/dadimenemo
Is there a way when exporting strm to not do anything that's already in the folder I've set for strm files? I have turned off the option in export service "before export to library, remove previous files and folders" under settings of add-on. What I'd like it to do is just export what's new.
@melmanc I see the issue. I'll fix it. Thanks for the report.
@alexprimaid I see you are trying to export the folder "movies" but entering from the "Music add-on" option. That won't work. I mean it would work and export something if you have some mp3 or other music files there, but I don't see it in your log. Looks like you the log was uploaded before the export process was finished. Anyway, make sure you are entering the addon thru the proper option if you want to export movies (Video add-ons). Let me know if you still have the issue and post your log again waiting for the export process to finish.
@chabs That's what the "watch" option is for. It will be watching for changes in your drive (including new files) and it will replicate only those changes in your local storage. It's different than a full export "run" (which you can do manually or scheduled), which will always go over all the files.
So, no matter what I do, I always get the message "Your code is invalid. Make sure you entered the code displayed in Kodi and you're in the same network as your kodi device," every time I try to authenticate. I have used three different devices (including the my Kodi device), and multiple wifi networks.
UPDATE - I figured it out! It was a problem on my end!
(2018-12-09, 22:43)jmiller33 Wrote: [ -> ]So, no matter what I do, I always get the message "Your code is invalid. Make sure you entered the code displayed in Kodi and you're in the same network as your kodi device," every time I try to authenticate. I have used three different devices (including the my Kodi device), and multiple wifi networks.
use the same ip
Hey I’m trying to get this add on to work with the cover art. They add the local source but it still doesn’t work. I think it might have somthing to do with it being in the shared folder. Am I missing somthing
see below.
 What was the problem you encountered on your end?  I've run into the same issue with the invalid authentication code.  Thank you!
