2020-02-19, 20:01
(2020-02-19, 09:11)alfiancc Wrote: [ -> ]Hello,same here, can't play nothing
Im having an error on Android : "_get_item play_url() takes at most 5 arguments (6 given)"
How to fix it?
Thanks in advance.
Regards.
How to fix it?
Thanks in advance.
Regards.
(2020-02-19, 20:01)jonsnow30 Wrote: [ -> ]just adding the complete error from the kodi log :(2020-02-19, 09:11)alfiancc Wrote: [ -> ]Hello,same here, can't play nothing
How to fix it?
Thanks in advance.
Regards.![]()
(2020-02-20, 09:59)scofield272 Wrote: [ -> ]FYI(2020-02-19, 20:01)jonsnow30 Wrote: [ -> ]just adding the complete error from the kodi log :(2020-02-19, 09:11)alfiancc Wrote: [ -> ]Hello,same here, can't play nothing
How to fix it?
Thanks in advance.
Regards.![]()
2020-02-20 09:50:12.312 T:23032 ERROR: [plugin.googledrive][MainThread-23032]: [plugin.googledrive][1.3.1]/[1.2.10]
unknown error:
_get_item_play_url() takes at most 5 arguments (6 given)
please try again.
File "C:\Users\Lenovo\AppData\Roaming\Kodi\addons\script.module.clouddrive.common\clouddrive\common\ui\addon.py", line 764, in route
method(**arguments)
File "C:\Users\Lenovo\AppData\Roaming\Kodi\addons\script.module.clouddrive.common\clouddrive\common\ui\addon.py", line 654, in play
subtitles.append(self._get_item_play_url(urllib.quote(Utils.str(subtitle['name'])), driveid, Utils.default(Utils.get_safe_value(subtitle, 'drive_id'), driveid), subtitle['id'], True))
TypeError: _get_item_play_url() takes at most 5 arguments (6 given)
show_error_dialog: True
2020-02-20 09:50:28.258 T:9196 WARNING: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 107, because topmost modal dialog closing animation is running
2020-02-20 09:50:28.577 T:23032 WARNING: Previous line repeats 7 times.
(2020-02-20, 10:07)scofield272 Wrote: [ -> ](2020-02-20, 09:59)scofield272 Wrote: [ -> ]FYI(2020-02-19, 20:01)jonsnow30 Wrote: [ -> ]same here, can't play nothingjust adding the complete error from the kodi log :![]()
unknown error:
please try again.
method(**arguments)
the issue seems to be in script.module.clouddrive.common-1.2.10, I've installed the older ver 1.2.8. and it works perfectly.
(2020-02-20, 16:06)xybydy Wrote: [ -> ](2020-02-20, 10:07)scofield272 Wrote: [ -> ](2020-02-20, 09:59)scofield272 Wrote: [ -> ]just adding the complete error from the kodi log :FYI
unknown error:
please try again.
method(**arguments)
does the related video has subtitles?
also do you have the same issue with the videos without subs?
(2020-02-20, 17:21)scofield272 Wrote: [ -> ](2020-02-20, 16:06)xybydy Wrote: [ -> ](2020-02-20, 10:07)scofield272 Wrote: [ -> ]FYI
now that you mentioned it, I checked with ver -1.2.10, only videos with external subtitles files gives the error "_get_item_play_url() takes at most 5 arguments (6 given)" , movies without subtitle files plays just fine ...
(2020-02-20, 17:25)xybydy Wrote: [ -> ]the issue happens in both, strm files and direct from the addon(2020-02-20, 17:21)scofield272 Wrote: [ -> ](2020-02-20, 16:06)xybydy Wrote: [ -> ]does the related video has subtitles?
Do you play it via exported strm files or just inside the addon?
(2020-02-20, 17:36)cguZZMan Wrote: [ -> ]The new google drive addon version is 1.3.3. That works with the common drive addon version 1.2.10. Make sure you have both versions correctly.
The problem is that the team kodi merged the common drive addon only and the google drive addon is still pending.
