(2018-04-20, 17:28)WeesteWatt Wrote: [ -> ]Ok. is it possible to scrape by .nfo when its added with .strm?
because I have created some own series with .nfo
Kodi will scrape the strm files as if they were regular video formats so you can opt to scan local meta if you want.
Is it possible that it works with .nfo in the future?
(2018-04-20, 17:32)beljim7419 Wrote: [ -> ] Kodi will scrape the strm files as if they were regular video formats so you can opt to scan local meta if you want.
where should the .nfo be placed? in the folder with the .strm?
(2018-04-20, 17:35)WeesteWatt Wrote: [ -> ] (2018-04-20, 17:32)beljim7419 Wrote: [ -> ] Kodi will scrape the strm files as if they were regular video formats so you can opt to scan local meta if you want.
yes.
To answer your question about adding as a source. Just go to add video source and enter
http://localhost:8585 in the address bar. It is slower though.
ok, i´ve the .nfo files in the folder with .strm and in the folder of the tv show in google drive and it dosent work. Any ideas?
you can't read nfo or meta directly from google drive. you need to export the .strm to a local folder.
Yes, I understood and did that. Normal series scraped KODI but just special for what I have created .nfo's do not work. Local it works.
----------EDIT---------
It works. ^^ Error was the user.
Your code is invalid. Make sure you entered the code displayed in Kodi and you're in the same network as your kodi device.
This is what I am getting trying to add a account
Anybody know that why I can’t see the pictures in context? I have save the cover page(jpg)in google drive,but when I open the file only can see the movie file,I can’t see the pictures?
(2018-04-19, 17:45)cguZZMan Wrote: [ -> ]https://drive-login
So I tried using the code from the "kodi-login" pop up in the "drive-login" url and it still wouldn't authenticate. I cant imagine what else the issue could be. There is no reason my network shouldnt be in the same network as my kodi. They are both on my wifi router server.
keithcq71 @
NOTSPAM after you selected the option "Add an account..." a popup is displayed with a URL and the code.
Please make sure you are using the URL the popup is giving you. There are only 2 options: kodi-login or drive-login. You DO NOT need to try to input the code in each of them, just use the one displayed to you in the popup.
If it doen's work, please send me your log:
https://kodi.wiki/view/Log_file/Easy
NeoU your log indicates your internet was intermittent at the time you tried to add the account or the server was temporary unavailable. Please try again and let me know. If you want to use the latest addon version you can install my repository:
https://github.com/cguZZman/repository.plugins
If you install the new version, the url to enter the code will change. Please make sure you use the correct URL.
samsam05 you are trying to view your pictures using the addon with the Video mode. To see your pictures, go to Add-ons > Picture add-os. If you want your music go to Add-ons > Music addons. Let me know..
https://paste.kodi.tv/quyedidalu
I'm not sure if thats right. I did it several times and twice it said file was too large. This link was the only one that showed up. I hope its helpful.
NOTSPAM your log doesn't have any activity with the addon. Please restart your kodi, try to add an account again and then generate the log file link.
