Can you continue to use the addon without creating strm?
(2020-04-13, 09:30)hangulsheep Wrote: [ -> ]Hi
Just an update of the above post. I managed to generate .strm for new folders when I chose the option "schedule automatic exports" for every startup. However, it generates the entirety of the folder, and not the "new" folders that were added. As shared earlier, I was hoping it will generate new .strm for the number of folders that were added, say 5-10 instead of the whole library that is inside the folder.
Appreciate the help on this, thank you!
I dont think automatic update is working .
You have to manually update in Kodi . Its not occuring automatically
(2020-04-28, 03:49)keithcq71 Wrote: [ -> ]You have to manually update in Kodi . Its not occuring automatically
Hi, is version 1.3.6 out yet?
The developer told me that he was going to push the update to kodi.
Anyone know how to manually update?
Thx!
(2020-04-22, 13:40)ntilikp Wrote: [ -> ]Would love to see this work with the new Shortcut feature that's replaced and expanded upon "Add to Drive" in Google Drive
+1. Shortcuts can be great for organizing stuff, but they're useless until this addon supports them.
(2020-04-30, 20:07)aerik Wrote: [ -> ] (2020-04-02, 07:05)aerik Wrote: [ -> ]Any way to remove from library the movies as deleted from Google drive?
Nobody?
Kodi Settings - media - clean library
Google Photos no mp4s listed. I'm also having the problem of movies in Google Photos only listed under pictures. Most of my videos are mp4, none of them show up, only mkv and avi, which play fine. If i make a favorite to the Google Photos movie folder all the movies including the mp4s are listed, but then nothing plays.
guys this add on can be compatible with kodi v19?
because in firestick 4k, kodi 18 up to date, 18.6, have desync of 300ms
And seems that v19 is fixed, but this addon tell me that isn't compatible.
There is a way?
Anybody getting duplicated covers when scanning movies?
Sadly I can seem to find a way to play 1080p remuxes using this addon after updating to 17.6. Is it a memory issue? System Info says that I have 900mb+ free even after playing the file...
(2020-05-01, 17:16)Alien0 Wrote: [ -> ] (2020-04-30, 20:07)aerik Wrote: [ -> ] (2020-04-02, 07:05)aerik Wrote: [ -> ]Any way to remove from library the movies as deleted from Google drive?
Nobody?
This takes hours, it's not feasible
