Hi all,
New version 1.4.2 is in my repository.
What has changed:
- Fixes the way the addon storages the metadata of configuration it needs. Before, it was using text files like "accounts.cfg", "exports.cfg", "export-x.items", etc. Now, it was changed to local sqlite databases (.db files). This was necessary to fix the "unknow error" that was randomly happen and corrupting the text files. This was a must and there is no way around. The addon will try to migrate your current cfg file to the new sqlite database,
but if your file is not readable or something happens in the process, it will create a ".failed" file and then just continue. If this happened to you, simply make sure to add your export or account again and you should be good to go. There was no other way to fix this problem and hopefully sqlite will resolve all issues related with corruption.
- Fixes the export and the "watch for changes" functionality. Sometimes, some videos or files were not exported. It should be working now. Remember that a full export is required to start looking for changes. This full export gets the metadata of the files that the addon requires for watching. This is stored in the export-items.db file. If this file is not found or does not contain the metadata for the export, it will do the full export automatically to get them.
- Artwork download is now possible. The complete list of artwork files, banner, fanart, folder, cover, etc., not just nfo. Just select the option "Download artwork" in your export configuration.
If you had selected the old "NFO" option here, you must select the "Download artwork" again. Sorry for this but just trying to keep the code clean.
- Export automatically skips unmodified files. It will not touch your existent strm or artwork files if it has the expected size which is the way the addon checks for modifications between your drive and local files.
- Now it is possible to play videos that are "shortcuts" from shared drives. This was a new feature of Google Drive and seem to be must to have in the addon.
So in conclusion, check your accounts and exports. Make sure the addon completes the first full export and the watch for changes should be working fine.
If you found an issue, go to github and open an issue there, with the full required information. https://github.com/cguZZman/plugin.googledrive/issues
Now I will try to answer some questions.
