Full Version: Google Drive for KODI
in my firestick 4k is very very slow now
impossible to use and scan.
in attachment my log, i hope that is possible fix it.
I delete my library with 500 tv series and 7000 movies
export strm is too slow, are days that scan, and firestick freeze a lot of times, so impossible to use.
previous version doesn't have this issue, but doesn't works anymore.
export strm from google is slow, but on windows, is fast.
Stay always on google drive watching changes.
I tried also with unistall and reinstall kodi 18.6 and 18.8 , same story.
https://paste.ubuntu.com/p/xQtCsBKSRN/
(2020-10-18, 23:23)robertus Wrote: [ -> ]in my firestick 4k is very very slow now
Go back to version 1.3.4
I was doing okay for about 1 day but it started failing to start again and it would just hang there indefinitely. Restarting kodi worked once but then it has failed on me for the last few hours and I am still working my way through my TV Shows.
I am hesitant to upload logs because all of the personal information in the log.
@robertus there are about 40 seconds gap between processing one change and another in your log. Between every change, sqlite updates are happening, so I just updated the addon to time these executions and see if sqlite is to blame or not. Try again with the new version.
Make sure you have this new version from my repo, then export again and then post your debug log file.
edited to remove log
(2020-10-19, 03:53)cguZZMan Wrote: [ -> ]@robertus there are about 40 seconds gap between processing one change and another in your log. Between every change, sqlite updates are happening, so I just updated the addon to time these executions and see if sqlite is to blame or not. Try again with the new version.
in first thanks, anyway I can see only 1.4.5 version into your rep, that is version that i used.
@ntilikp - The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2020-10-19, 01:32)Droidly Wrote: [ -> ]
1.3.4 say accountmanager error or something like that, doesn't works
and dev, said to use new version, but from rep, there is 1.4.5 and i used it, but i have an issue with it
1.4.6 is in the repo
(2020-10-19, 14:15)cguZZMan Wrote: [ -> ]1.4.6 is in the repo
https://imgur.com/a/PgqYtUX
EDIT: now is available, thanks, i'll try now!
as you know, thanks always for this amazing job
Unfortunately, seems that issue isn't be solved.
https://paste.ubuntu.com/p/B9pWQwmWKY/
(2020-10-19, 15:45)robertus Wrote: [ -> ]Unfortunately, seems that issue isn't be solved.
Go back to plugin.googledrive-1.3.6 add-on with the corresponding common drive module 1.2.15 from Carlos's github.
https://github.com/cguZZman/repository.p...oogledrive
https://github.com/cguZZman/repository.p...ive.common
I don't know why but if and when the add-on gets stuck loading I am able to completely resolve this by manually deleting both the google drive add-on and common module then reinstall manually.
Using kodi uninstall reinstall does not fix it.
FYI
Also, as I have been working through adding 800+ TV Shows library I am getting 20%-25% EMPTY series folders generated with NO seasons. So far I am at the 650 series added point.
Happily, only 1 empty season got created so far without any strm's in the folder.
(2020-10-19, 17:49)Droidly Wrote: [ -> ]
Thanks, right now I'm trying in this way.
Anyway I hope in a new build that works like expected in my Firestick 4k.
