novice question but can someone explain why I would need to 'schedule full exports' if I have the 'watch for changes in cloud folder' selected? I've never really understood it completely so I keep both checked but exporting takes long. Can anyone explain this to me?
thanks for the new repository information -- just downloaded the 18.7 version and that fix was perfect for me
Firestick not 4k, without sd card for storage ( like my firestick 4k where last build of this addon, make issue )
Here kodi.log
Issue: doesn't create any folder and strm files.
https://paste.kodi.tv/reneleraqi.kodi
(2020-10-25, 12:08)robertus Wrote: [ -> ]Firestick not 4k, without sd card for storage ( like my firestick 4k where last build of this addon, make issue )
Here kodi.log
I face the same issue but in my case it's android tv and I don't know how to create log files, the addon just worked fine until 3 or 4 days, now after installing version 1.4.8 from the repository and expoting .strm files ,some times they work fine and sometimes they just create empty tv shows or don't export at all no matter how many times I try. Does any one have the solution for this issue
(2020-10-25, 12:18)Supreeth Wrote: [ -> ] (2020-10-25, 12:08)robertus Wrote: [ -> ]Firestick not 4k, without sd card for storage ( like my firestick 4k where last build of this addon, make issue )
Here kodi.log
Kodi - Settings - System
Setup Expert on left and go into Logging
So enable debug logging
I guess that is time to mount in my raspberry, my team drive, and share folder with kodi, to avoid any issue, if are impossible to fix
Here kodi.log
reneleraqi.kodi (paste)
Your debug log is incomplete, but says it created 34 strm files in your local Download folder. All looks good in your log file. I would need a complete log file or just make sure you are checking the correct folder.
And about your Firestick 4k, now it make sense. If you are using the SD card to storage your strm files, you should use a fast one. Class 10 or something similar. SQLite needs an storage with good performance. Or just try with the internal memory.
(2020-10-25, 17:37)cguZZMan Wrote: [ -> ] (2020-10-25, 12:08)robertus Wrote: [ -> ]Firestick not 4k, without sd card for storage ( like my firestick 4k where last build of this addon, make issue )
Here kodi.log
Complete log i didn't understand how.
Anyway another log from Firestick not 4k, with internal memory, and yes i check correct folder, and is empty.
https://imgur.com/a/fmvXW47
As you can see also, cpu is pretty high and is stuck on there, watching changes.. and nothing create in folder.
https://paste.kodi.tv/amenijiqof.kodi
Does the source option works ?? I added it as source and got some shows scanned into the library. But failed to play the video, Exporting some shows as .strm files is not working
No, there's written in the first page.
Failed to export .strm files, here is the log file for that
https://paste.kodi.tv/budoxetaqi.kodi
Sorry, if I did anything wrong in log file as this is my first time in creating a log, and also sorry for my english, please let me know how to fix the issue
Moving / altering a folder with a large number of files (like a BDMV folder) anywhere in google drive, not just the watched folders, will cause the add-on to "process changes" for an hour and a half or so. Not much of a problem if you know what's causing it and just handle folders like that on a different google account, but I'd thought I'd post it here since it took me a minute to determine the cause. I presume the api needs to watch for changes across all of GD and can't be focused to just the folders that export to .strms?
That is correct. The API provided by google watches on the entire drive. Once the changes list is provided to the addon, it has to check if any of these changes belong to any exported folder and act accordingly.
You can disable the progress notifications in the addon settings if this causes annoyances.
Hello, i am getting error notices apparently related to this addon. Something about an "ascii' codec can't decode byte 0xc3 in position..."
Everything still seems to work so far, the only related thread i could google is from the emby forum, the problem seemed to be a special character in the naming of a file. I went through my recently added files on Google Drive and couldnt find any typo's.
Maybe you can help me figure it out. Here is my log file:
Log File
Mystere
2020-11-10 19:01:03.514 T:7388 NOTICE: ADDON: repository.supremebuilds v1.0.2 installed
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
