Full Version: A few ideas i had
Hello long time kodi user here, not so long android kore user. I have a few feature requests.
1. Option to make app fullscreen (immersive full-screen mode)
2. Be able to create skins for the app
3. Start app on boot up
4. Dim screen if not in use
5. Be able to connect via Bluetooth
6. Use phone ir transmitter
7. Show battery status
The story, i am currently using a samsung s2 as a kodi remote. I have made the app boot up at start up and go into full screen immersive mode hence to show battery status. Also the s2 has a small screen so my fat fingers press the wrong buttons sometimes. So would be fantastic if i could design a skin with bigger buttons and less info on screen. I also use a Samsung Note 4 that has ir transmitter built in also i believe you can get an adapter that plugs into the headphone jack in phones. Since i am using my s2 to conntrol kodi and is always on it would be good if the screen dimmed to save power also so not so bright.
These are just ideas to make the app that much better. Wish i could help but only good at hacking, modding and skinning.
