Full Version: How to install an addon from ZIP file in Aeon MQ 7 Krypton Skin?
i have a problem. I want to install an addon for aeon mq7 kryton via zip file but i don't found "Install from ZIP file" option under addons?
Where can i found "install from zip file" please? View is on "expert"!
in other skins it is there but my problem is i must install it when mq7 krypton is activated...if not the addon will not work.
Thanks in advance
Mark
(2017-12-01, 13:10)MarkB78 Wrote: [ -> ]Hi,
Thanks in advance
Mark
Just go to SETTINGS -----ADDONS--------
And you'll find install from Zip
Unbelievable...i tried it several times and it was not there...after another restart it was there...magic? I believe so.
Thanks Smile
(2017-12-01, 17:28)MarkB78 Wrote: [ -> ]Unbelievable...i tried it several times and it was not there...after another restart it was there...magic? I believe so.
Thanks Smile
 Well, at least you got it working Smile
