2017-12-05, 15:02
Pages: 1 2
2017-12-05, 15:20
(2017-12-05, 11:30)orzechszek Wrote: [ -> ]@jjd-uk - you think about hub based harmony remotes, or something else?I don't understand?
Yes as I said before, I was talking about the Harmony remotes which make use of the Harmony Hub, the Hub supports both Bluetooth and IR and I see zero lag using bluetooth to my Libreelec install.
2017-12-05, 23:44
Thanks for help. I've configured it with IR receiver. Works a little better, but not fluent. When I'm clicking fast it looks like remote is waiting for something.. and then click. Aslo when I'm clicking fast, it remembers previous clicks and repeats. Not noticable with samsung TV through CEC.
What configuration do you have in MyHarmony (delays, repeats, etc)?
2017-12-06, 05:33
Try reducing the number of times each command is repeated by the Harmony remote - the default is 3 times which is excessive. With the latest 4.14.y kernel in LE9 test builds a repeat rate of 1 works just fine while also reducing lag, and may also give better performance with the older 4.11.y kernel in LE 8.2.1. Instructions on how to change the number of command repeats can be found here.
2017-12-08, 12:35
I've already reduced repeats and check with LE 8.2.1. Also I check with other values. Still no comparable to samsung TV remote work. Any other configuration changes?
Below a video with comparison:
https://we.tl/r8Bn1ao0K9
You can see slightly difference between reactions.
2017-12-08, 20:12
(2017-12-08, 12:35)orzechszek Wrote: [ -> ]I've already reduced repeats and check with LE 8.2.1. Also I check with other values. Still no comparable to samsung TV remote work. Any other configuration changes?
Not that I'm aware of. Are there any other Samsung remote profiles in the Harmony database? Maybe you've picked a duff one?
2017-12-08, 22:54
I set my TV version, so should be proper. Remote works with TV. For IR steering harmony is configured as Microsoft -> KODI.
2017-12-11, 20:31
Any new ideas ?
Any new ideas ?
2018-01-03, 17:56
No news? I'm still struggling with it..
Previous video: https://we.tl/Ke7hYG4ymj
Pages: 1 2
