Full Version: Login problem bug tracker
When I try to login in the bug tracker I get the error "Invalid username or password".
It is not clear to me why, as I use the same username and password combination as I used to login on this forum.
Please give me directions to overcome this inlog problem so I can add the bug I found in the bug tracker.
Thread moved to website issues
only thing to keep in mind is that trac login is case sensitive.
for the rest i can't think of a reason why it wouldn't work for you.
(2017-12-03, 14:47)ronie Wrote: [ -> ]only thing to keep in mind is that trac login is case sensitive.
Thank you for your reply. I have chosen to reset my password and I was able to add my bug report in the bug tracker.
Changing back my new password to my old one did not work out yet. Will try again tomorrow.
Thanks,
Baderks
