Having an internal harddrive, and one usb-harddrive
Dont know the version of KODI, but just recently got it from the play store
Using android as OS, and i cant find any of my drives inside KODI.. is there a specific search-path to look for?
One disc is a 4tb seagate Ironwolf, the other is a 2tb Segate (external usb-disc)
//najkks
Make sure your drives are not in some hibernate state and properly disconnected from Windows. Also double-check for any disk errors. Linux can be picky when mounting non-Linux drives.
yes KODI installed now
well i did fint them, and scraped okey
but why cant i find the discs in my network?
it would be easier to transfer new files into them thru the network i think!
im having same problem i cant connect to smb workgroup on android, windows or raspberrypi
why is this?
should'nt it be more easy to access the harddrive/disc mounted to the egreat-player than this?
Look under videos > files and see if they are there.
That's where usb drives normally appear and can be scanned or added to the library via their context menu.
Suddenly KODI wont allow me to use the "backwards /return" button
So i have to restart everything if i want to jump back to the earlier menu
Can someone explain if this is normal?!
nevermind, found the button on the remote for backwards
hmm.. Master key lock - how do i disable that?
don't know why it appeared, but now i almost always have to enter a 4-digit code to change the settings in KODI
