Full Version: TVshow time add-on
Pages: 1 2
hi
i have installed the tvshow add-on, but the sync with kody doesn't work.
could someone help me?
Which addon are you referring to?
And it is "Kodi", not "Kody".
(2017-12-03, 21:25)nickr Wrote: [ -> ]Which addon are you referring to?
 sorry for mistake Big Grin
i'm referring to tvshow time add-on
I think i found it, hadn't heard of that one before.
Have you followed these instructions? http://kodi.wiki/view/Add-on:TVShow%20Time
Yes, I did, but when I try to synchronize Kodi with TVShow Kodi returns me an error
debug log (wiki)
i haven't the skills for debug Sad
He means grab the log, upload it to PasteBin.com and post the link they will give you here so we can look at it.
Details on how to do it are in the link above.
(2017-12-05, 22:36)brenny Wrote: [ -> ]i haven't the skills for debug Sad
Click the link I gave you. It is not rocket science.
Blush
pastebin returns me this:
You have exceeded the maximum paste size of 512 kilobytes per paste. PRO users don't have this limit!
Try this site... https://paste.ubuntu.com/
Make sure you restarted Kodi after enabling debugging. The replicated the problem.
this is the link, thanks
https://paste.ubuntu.com/26131623/
Hi
no news?
The log doesn't show any errors (although a huge amount of activity from that add-on) until right at the end when it's having problems accessing the Van Helsing series (23:29:39.026 T:140695402702592 ERROR: Open - Error, could not open file /share/SERIE.TV.HD02/Van Helsing/S01/Van.Helsing.S01E01.Aiutami.DLMux.720p.ITA.ENG.SUBS-DDV.mkv).
What exactly is the issue that you're seeing from the user viewpoint? Is that item actually available at that location? Earlier in the log there are other shows successfully processed, but they seem to be on another drive or area (HD01 rather than the HD02 above).
As noted above, this seems to be an old and not very well known/used add-on (I'd never heard of it either until your thread) so it may just be that it's outdated and needs some update to work properly with current versions of Kodi.
I've been using it for a long time but since a month it stopped working on Kodi.
it always produce the following error:
01:56:31.930 T:5608 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('unknown',)
File "C:\Users\mgharaibeh\AppData\Roaming\Kodi\addons\script.tvshowtime\default.py", line 110, in onNotification
item = self.getEpisodeTVDB(xbmc_id)
File "C:\Users\mgharaibeh\AppData\Roaming\Kodi\addons\script.tvshowtime\default.py", line 269, in getEpisodeTVDB
log('episode_id=%s' % result['result']['episodedetails']['uniqueid']['unknown'])
KeyError: ('unknown',)
Please help,
Pages: 1 2
