2017-12-13, 01:16
Would be nice to have lossless bitstreaming, but agree that Neural:X is terrific! I use it for everything (DD, DD+, TrueHD, DTS, HRA, MA). I only listen to actual ATMOS & X straight w/o any processing.
(2017-12-18, 03:45)mozomo Wrote: [ -> ]The three problems I have with the 4k, although it's a really good product:Go into MrMC Video Settings, when TV is playing. And select Deinterlace Method > Deinterlace to get YADIF2X full motion deinterlacing.
- Deinterlacing is fine, but not very good. Live TV looks better on other devices. Especially news-crawlers make the 4k sweat
Quote:- "real" 24fps is played out as 23.976. Which results in a dropped frame every 40 seconds or so. That's not really problem, but it gets annoying while watching a show like "DARK" in Netflix. After you've noticed it, you can't help but wait for the next dropped frame (Luckily there is not too much 24fps content around)Not seeing this at all - everything is silky smooth for me using all Apps.
Quote:And about MrMC: It works fine, but the skin is incredibly ugly IMHO and I miss some addons.I use Amber Skin with the Vertical Menu on the Left. I'm hoping for a Krypton type Skin backport - yes I do miss Krypton's Estuary Skin.
(2017-12-18, 04:08)wrxtasy Wrote: [ -> ]I'll have to try again in MrMc. Maybe I just tried Yadifx2 only in TvhClient, where it makes the BBC-news crawler jump and I did not bother in MrMc(2017-12-18, 03:45)mozomo Wrote: [ -> ]The three problems I have with the 4k, although it's a really good product:Go into MrMC Video Settings, when TV is playing. And select Deinterlace Method > Deinterlace to get YADIF2X full motion deinterlacing.
It will be very nice then
Then "Set as default for all Videos" down the bottom.
(2017-12-18, 04:08)wrxtasy Wrote: [ -> ](2017-12-18, 03:45)mozomo Wrote: [ -> ]- "real" 24fps is played out as 23.976. Which results in a dropped frame every 40 seconds or so. That's not really problem, but it gets annoying while watching a show like "DARK" in Netflix. After you've noticed it, you can't help but wait for the next dropped frame (Luckily there is not too much 24fps content around)Not seeing this at all - everything is silky smooth for me using all Apps.
Watched "Dark" last week on Netflix and did not see any skips at all. The best test is the Subtitles at the end when they are scrolling on the screen.
Sounds like a settings issue. (possibly even TV interpolation settings)
(2017-12-18, 08:36)mozomo Wrote: [ -> ]Strange. I am sure that I saw it and I am not the only one. It reminded me of one of my old intel htpcs with it's 24fps bug.Ah, I see. Weird I did not see it. Might have a look at the scrolling credits again to see if I can pick up anything.
(2017-12-18, 09:33)wesk05 Wrote: [ -> ]The Sony 4K Camp HDR video has totally wrong HDR10 metadata in the SEIIs that Sony Camp 4K HDR test clip even BT.2020 ?
(2017-12-18, 10:20)wrxtasy Wrote: [ -> ]ATV4K seems to have only fractional refresh rates (59.94/23.976) support. No 60 or 24Hz.(2017-12-18, 08:36)mozomo Wrote: [ -> ]Strange. I am sure that I saw it and I am not the only one. It reminded me of one of my old intel htpcs with it's 24fps bug.Ah, I see. Weird I did not see it. Might have a look at the scrolling credits again to see if I can pick up anything.
Mediainfo of the supposed Sony Camp 4K HDR I have is reporting BT.709 8bit - the filename looks incorrect.
EDIT: just to check I downloaded Sony Camp again from:
http://4kmedia.org/sony-camping-in-nature-4k-demo/
And sure enough 8bit BT.709 again.
Quote:General
Complete name : Y:\AV Test Clips\4K Demos\(HDR HEVC 10-bit BT.2020 59.940fps) Camp by Sony.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom)
File size : 1.12 GiB
Duration : 2 min 7 s
Overall bit rate mode : Variable
Overall bit rate : 75.8 Mb/s
Encoded date : UTC 2016-02-03 08:01:30
Tagged date : UTC 2016-02-03 08:01:30
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@high
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 75.6 Mb/s
Maximum bit rate : 123 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.152
Stream size : 1.12 GiB (100%)
Encoded date : UTC 2016-02-03 07:59:49
Tagged date : UTC 2016-02-03 08:01:32
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : R: x=1.000000 y=1.000000, G: x=1.000000 y=1.000000, B: x=1.000000 y=1.000000, White point: x=1.000000 y=1.000000
Mastering display luminance : min: 0.1000 cd/m2, max: 0.5000 cd/m2
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : mp4a-40-2
Source duration : 2 min 7 s
Bit rate mode : Variable
Bit rate : 192 kb/s
Maximum bit rate : 197 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 2.91 MiB (0%)
Source stream size : 2.91 MiB (0%)
Language : English
(2017-12-18, 18:23)jaymillerSR Wrote: [ -> ]@wrxtasy does ATV4k kodi support Siri to text instead of keyboard typing? Kinda like the shield does with spmc?I have not sideloaded Kodi - but MrMC (Kodi Jarvis) uses the standard tvOS text input screen where Siri speech to text works quickly and without fuss
