While trying to install the "Time" magazine add-on from the Kodi Add-On Repository I received a message, "...failed to install a dependency." I realize that the add-on I am trying to install may very well be dependent upon other features of which I may not be aware. However, I would like very much to install this add-on (and possible others with the same error message). Is there some method by which I can find out the dependency that is lacking and install it myself so that I can install these add-ons or am I just SOL?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
