2017-12-07, 14:35
I'm a new Kodi user. I'm running Ubuntu 16.04 desktop with the default Kodi package. I have Kodi as an automatic login so the machine comes up in Kodi on its main screen. I've imported a large number of movies and TV shows. The scraper has mostly done an OK job, and I've been gradually fixing things up.
The problem is that Kodi will hang on "Working..." on random videos. I can't tell in advance which ones. There seems to be no way to break out of "Working..." using any of the controls. In fact, the only way I've found to recover (short of power cycling the machine -- definitely not OK for this machine) is to attach a keyboard, use CTRL-ALT-F1 to get to the console, log in, and use "sudo kill -9" on the kodi.bin process.
Since it happens to random videos, this makes Kodi a bit unusable.
What do?
Thanks all.
What do?
Thanks all.
