2017-12-09, 01:00
2017-12-09, 01:07
So what is this going to do? Keep Kodi updated without my intervention I hope. That is the one linux thing I really miss.
Sent from my MI MAX 2
2017-12-09, 01:29
This plugin facilitates downloading and installing Kodi updates "Manually"... there is no automation.
2017-12-09, 01:31
Still easier than opening a browser and downloading it. I'll take it. Thanks as always.
2019-02-01, 19:17
This doesn't work with Kodi version 18. It installs okay, but when I try to run it, I get a message saying "UWP installations not supported". I'm not running a uwp version. I'm running the exe version. I was running the uwp version, but deleted it after all the problems the version 18 update caused.
2019-02-02, 00:04
Sounds like your UWP uninstall left some vacant folders which is causing a false positive. I'll push a fix to correctly identify UWP installations.
2019-02-02, 01:26
2019-11-18, 12:16
@Lunatixz
Just in the last couple of days there are no files listed in the folders when using this addon to select the version that you want to install/update. The folders are there and the folder structure is there (e.g. you can navigate up and go to other folders that exist) and checking http://mirrors.kodi.tv/nightlies/ in a browser there are definitely files in those folders as normal, just not via the addon. I thought it might be a skin-based issue, but same after switching to the default Estuary skin.
I update to the latest nightly for win64/Leia/ regularly and currently have 20191116-37f51f6e (from 18-Nov) installed.
2019-11-30, 02:46
(2019-11-18, 12:16)b'sketti Wrote: [ -> ]@Lunatixz
Yes, mine is doing the same. Bit of a mystery this one
John
2019-11-30, 03:38
Install my beta repository to receive pre-release builds.
2019-12-03, 03:28
(2019-11-30, 03:38)Lunatixz Wrote: [ -> ]Install my beta repository to receive pre-release builds.
Thanks, that worked...
