Full Version: Version 2.9.6
10.12.2017 - Version 2.9.6
+ add persian language
+ added option to include external audio files in Kodi NFO streamdetails (thx @midgetspy)
+ support for mediainfo 17.10+ XMLs
+ updated mediainfo to 17.10
+ fixed java 9 compatibility issues
x fix parsing MediaInfo for .ISO files (endless hanging sometimes)
x reduced log output on the console for the command line version
x fix animated pictures scraper; did not work on automatic scrape
x fix AniDB scrape (too much results)
x fix country tags in NFO (now multiple)
x change episodeguide url in TvShow NFOs
x cleaning of orphaned episodes in the database
x storing of episodes in special seasons (season 0) no more switches to season -1
x fix occassional crashes when writing objects to the database
x fix audio codes parsing of audio files (thx @midgetspy)
x fix renaming of movies with renamer token $2 and starting with umlauts
Awesome thanks for the hard work guys.
One question what is different or changed with
Where can I read about that?
Thank you!.
@Ruk12345 is you create a mediainfo.xml with the latest mediainfo version, the xml looks different. We just added this syntax in 2.9.6 Smile
(2017-12-11, 10:09)mlaggner Wrote: [ -> ]@Ruk12345 is you create a mediainfo.xml with the latest mediainfo version, the xml looks different. We just added this syntax in 2.9.6 Smile
