2017-12-13, 01:58
2017-12-13, 10:06
no... they're part of the added functionality.. i think if you play around with them you'll find them useful.
cheers!
cheers!
2017-12-13, 19:02
(2017-12-13, 10:06)fastcolors Wrote: [ -> ]no... they're part of the added functionality.. i think if you play around with them you'll find them useful.I wouldn't mind them, but the problem I found is they are not clickable. I can highlight them, but it won't do anything if I select it. Maybe there is a setting I need to change.
cheers!
2017-12-16, 20:49
(2017-12-13, 19:02)cincyplanet Wrote: [ -> ](2017-12-13, 10:06)fastcolors Wrote: [ -> ]no... they're part of the added functionality.. i think if you play around with them you'll find them useful.I wouldn't mind them, but the problem I found is they are not clickable. I can highlight them, but it won't do anything if I select it. Maybe there is a setting I need to change.
cheers!
what are they populating with? movies? can you send me some more infos?
