Full Version: Qodi and official repository
I recently purchased and set up an Android set top box (eshowee w95). It came with Qodi installed, which I understand is a form of Kodi. I also understand that support for Qodi likely isn't provided on this forum.
The official repository doesn't work for me - whenever I try to access it, I get a "could not connect to repository" message. I figured it's something to do with it being Qodi rather than Kodi, but when I got to the Android play store to install Kodi instead, it says it's already installed.
How do I get around this? Either by manually entering the repository info, or by installing the actual Kodi program?
Thanks in advance,
Lee
You'll have to provide a KODI log...
http://kodi.wiki/view/Log_file/Easy
Um.....
The instructions in that link direct me to install a log file add-on... from the official repository.
Is there another way to install it?
Sent from my SM-N920T
Try downloading from here... https://kodi.tv/addon/program-add-ons-sc...e-uploader
Install via zipfile
I didn't read your first post when I posted above. I was simply answering your question how to upload a log.
You are correct, we do not support Qodi here in this forum. Yes, it is a fork of Kodi. We have no idea what has been done to it. It is also banned item in this forum.
Can you please clarify if you have Bee-Link with Qodi or Kodi.
Try uninstalling Qodi then installing the real deal Smile
