Full Version: Howto add extra MP3 tag information in full screen mode (Music)
I would like to add some extra mp3 tag information of the music being played on the full screen mode.
It looks default like this (with Title + Artist + Album):
I would like to add the Year somewhere. For example behind the Title:
I've been searching the internet and the xml files in \AppData\Roaming\Kodi\addons\skin.fuse.neue\ but I cannot make heads or tails from it.
Is this rocket science? Or doable?
Hmm, lots of views but no reply. I guess the adding of extra mp3-tag information on screen is not that easy to accomplish...
Edit 1080i/Includes_OSD.xml
You need to edit the OSD_Music_Info include
If you want to add it to the title, look for the label control with the following label (line 59).
<label>$INFO[Player.Title]</label>
You need to add $INFO[MusicPlayer.Year, (,)] to that label
The part after the first comma is text to add before the label, and the part after adds it to the end of the label - so in this case you will get parentheses around the (year).
Add the info label like so:
<label>$INFO[Player.Title]$INFO[MusicPlayer.Year, (,)]</label>
I'm seriously grateful for your reply. It's simply spot-on.
It works like a charm.
