2017-12-15, 20:07
First time poster but I have been using Kodi with NextPVR on the backend for quite some time and it had been working great. My issue just happened in the last day or so when I try to watch TV in Kodi 17.6 (or 16.1 on another AndroidTV) running AndroidTV connecting to a NextPVR 4.0.5 backend. This issue was not present 4.0.4 until yesterday and no upgrade had happened for weeks. I did upgrade it today to 4.0.5 as i thought maybe it was a bug in 4.0.4. For some reason Kodi will attempt to open the stream on the channel but just constantly spin and hang. The only way i could get kodi to work again was to force stop it. After much testing and seeing if i could figure out what happened, I finally noticed that the Timeshifting feature of the plugin isn't working. Once i disabled that, LiveTV would load again, albeit a little slower than normal. I tried to see if anyone had this issue but i found nothing. I am guessing this is a new issue either with the plugin or with NextPVR so I thought i would post this here and see how far it can go here before i post elsewhere. Anyone else having this issue? I can provide logs, maybe, not sure how to grab them from AndroidTV and put them up here. Thanks!
