It's a particular set of x265 encoded video that seems to crash Kodi on demand. Other x265 videos work just fine.
Any ideas? I have logs, stacktrace, and a dump.
For now, here is the log:
http://paste.ubuntu.com/26195740/
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2017-12-16, 20:40)Karellen Wrote: [ -> ]The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Darn kids these days...
I could not remove the following, can you please help or are these benign?
D:\temp\kodi\log2.txt:82:20:36:06.250 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.covenant.metadata has been
installed.'
D:\temp\kodi\log2.txt:121:20:36:06.251 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.covenant.artwork has been
installed.'
D:\temp\kodi\log2.txt:146:20:36:06.252 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.module.covenant has been
installed.'
D:\temp\kodi\log2.txt:110:20:36:06.251 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.exodus.artwork has been
installed.'
D:\temp\kodi\log2.txt:116:20:36:06.251 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.exodus.metadata has been
installed.'
D:\temp\kodi\log2.txt:74:20:36:06.250 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.rebirth.metadata has been
installed.'
D:\temp\kodi\log2.txt:136:20:36:06.251 T:3932 DEBUG: ADDON: cpluff: 'Plug-in script.rebirth.artwork has been
installed.'
new log:
http://paste.ubuntu.com/26210273/
No they aren't benign and should be removed.
Close kodi, open windows explorer and go to C:\Users\werner-htpc\AppData\Roaming\Kodi\addons
In there you should find a folder for each addon. Delete the ones listed above and restart Kodi. That should remove the remnants.
Then grab another log, upload it and repost.
