2017-12-18, 23:06
2017-12-27, 12:05
Maybe TvHeadend?
I have no experience with it (yet), but it has a configuration addon within Kodi.
2017-12-27, 14:18
There is a setup script for TVHeadend, look under the TV Headend threads. it is a full setup script that can interface with the the TVHeadend backend.
2017-12-27, 14:38
(2017-12-18, 23:06)DexterF Wrote: [ -> ]Is there any DVB backend at all who I can tell from Kodi to scan for channels and arrange them afterwards?I don't think you can scan via the kodi interface with tvh, you scan via a webpage. there is an addon, https://forum.libreelec.tv/thread/9184-t...interface/ but I don't know if you can scan from it.
you can sort channels via Kodi though.
2017-12-27, 14:42
@bubblegum57 hate to contradict someone, but you can:
Here is a script that does just that here: https://forum.kodi.tv/showthread.php?tid=317841
and if you want schedules direct, which is by the same dev, here: https://forum.kodi.tv/showthread.php?tid=317893
I wanted to edit these into my previous post but you beat me!!
EDIT: oops - different forum same script. Sorry
2017-12-27, 14:45
(2017-12-27, 14:42)tjay260476 Wrote: [ -> ]@bubblegum57 hate to contradict someone, but you can:I don't mind you contradicting me if I'm wrong. I couldn't remember, I just scan via the webpage. But, as you know, it will update now & again anyway.
2017-12-27, 15:02
I remember as a new user looking at the webpage, and it looked overly complicated, so I can appreciate why someone would want to do it via Kodi, although the setup script via the webpage is better. But as you said, once done, can be left alone.
@DexterF on Libreelec, TVheadend can be installed via their repository, then just install the scripts, I think they're third party, so will have to be installed via zips, like @bubblegum57 can't remember, which probably shows you that once you can sit and leave it, although looks complex, once done, leave it. Either way on scanning it does the job.
2017-12-27, 15:06
I have just looked at my backend, I have the tvh2kodi addon already installed.
