2017-12-20, 05:08
Hello,
Not sure where to have posted this so thought I'd shove it here.
Running LibreELEC (bare with me) on Kodi 17.6. It appears if I use a video source using internal SMB it will pull video metadata without having to play the video (3d, audio, res etc), but if I use FTP (via dyndns for the NAS thus external) then it won't grab the metadata at all unless the file is played. Which is a bit meh considering they are basically duplicated in the library listing, and confusing when you're not sure which one is which.
Now I seen a github request where someone had this issue but lacked details to verify if they were the same protocols but the response from the dev was that it's normal for the metadata to only be grabbed once played, yet it grabs it without doing so using SMB. Is this a protocol thing? Internal vs external thing? Or is my Kodi special and shouldn't be doing it at all?
Best regards
Best regards
