2017-12-20, 19:05
Hello there,
I'm currently trying to write an Estouchy mod for Android, basically a vertical UI with a bigger font. It goes slowly because....I'm a total noob trying to understand how it works.
My problem is, if the horizontal text size doesn't fit the text box size, it will be cropped. So, even if it fit vertically, the text is cropped (also I'm not a native english, as you can see ).
Cropped text
I would like to know if it comes from Kodi itself and if it can be corrected, by an update or by changing the method the text size is calculated.
I just increased the text box size for the moment, but I'd like to avoid making gigantic buttons for every setting.
Increased textbox size
Well , thanks in advance for the help.
Cropped text
