Full Version: Android TV 7: Voice search no longer working
Hi all, I have searched but have not came across anyone else having the same issue:
It seems that after the android TV 7 upgrade with the new assistant, and the latest nightly of v18 voice input no longer works on Kodi as it once did see:
https://youtu.be/SrL3EDY3Pyk?t=2m47s
Does anyone know of a fix, or a build that it works on?
Moved from Development to Android forums
Just pull up the onscreen keyboard and long press select on the remote, that will allow for voice input.
(2017-12-22, 03:10)stewartie4 Wrote: [ -> ]Hi all, I have searched but have not came across anyone else having the same issue:
Same issue, no voice to text within kodi
Seems no one cares to read
Same issue with 18-beta2 on Nvidia Shield TV 2017, Android 8.
The workaround with long press doesn't work.
