2017-12-22, 19:47
Since past few days I see that my main kodi freezes every now and then and have to restart it if I still need to use it to view movies/TV shows. My setup is as follows:
kodi@dv6 (this one freezes all the time):
Kernel: Linux 4.4.0-104-generic #127-Ubuntu SMP Mon Dec 11 12:16:42 UTC 2017
Release: Ubuntu 16.04.3 LTS (Xenial Xerus)
Kodi (17.6 Git:20171114-a9a7a20) x64 build
Kodi application autostarts using upstart (probably why I can't kill kodi but have to logoff/logon after every freeze)
All content on an external drive which is always connected. Movies and shows are exported using NFS.
MySQL DB running on this machine.
Kodi@firestick - No issues. Using advancedsettings.xml to connect to DB and media from NFS.
kodi@laptop - No issues. Using advancedsettings.xml to connect to DB and media from NFS.
Whenever I observe kodi video playback freezing its the only instance reading media from disk. No other kodi instance is in use.
So when I start playing video file, after random duration (few seconds to few minutes) video playback just freezes. After I logoff and log back in have to start the whole process again. 'In Progress' is not updated with this video.
Logs are quite cryptic hence not too sure what is the problem but a crashlog file says below:
17:01:46.913 T:140159882360576 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41708
17:01:52.354 T:140159882360576 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
17:02:01.465 T:140159966189312 WARNING: Previous line repeats 2 times.
17:02:01.465 T:140159966189312 NOTICE: CVideoPlayerAudio:rocess - stream stalled
17:03:26.552 T:140159974582016 WARNING: VideoPlayer::Sync - stream player video does not start, flushing buffers
I am not too sure if this is where it stalled or this was a previously logged message.
Any help/suggestions would be appreciated - please share detailed steps to provide troubleshooting info.
